09-26-2021
21:25
10:29
DavideFitbit
09-26-2021
21:25
10:29
DavideFitbit
I have had the new Charge 5 for 2 days. The battery discharges within a day. GPS is off, the phone is not set to always on. In looking over the troubleshooting instructions from Fitbit, it seems that you essentially have to disable all of the features that were selling points of this device in order to get decent battery life. Even my ancient Charge 3 got 6 days on one charge! Has anyone with this battery problem found a solution other than disabling everything?
07-18-2022 19:31
07-18-2022 19:31
I've done the download for what it said was 20001.149.11 but when it finished, 20001.171.50. Nothing was mentioned about battery issue fixes, so let's see what happens.
07-18-2022 19:33
07-18-2022 19:33
There was a new firmware today, let's see if that finally fixes it (there doesn't seem to be any documentation confirming it either way which is not encouraging). Interested in feedback on the firmware update from anyone on this post.
Best Answer07-18-2022 19:43
07-18-2022 19:43
They'll document it when they figure out if it helps...
07-18-2022 19:53
07-18-2022 19:53
I updated the firmware on my Charge 5 and my battery has drained by 23% in 2 hours. Also, I can’t recharge it. The last time this happened, I had to delete the thing from the app and reinstall it.
Best Answer07-18-2022 22:52
07-18-2022 22:52
I updated my C5 after charging to 88% last night and when got up this morning the battery level had increased to 93%. 🤯
07-18-2022 23:07
07-18-2022 23:07
I'm having this problem for the first time since I got it last Christmas. I charged it to 100% just before I went to sleep. Took it off charge and wore it like I usually do to sleep and it was dead when I woke up. I've tried charging it and it got to 30% but as soon as I took it off charge it dropped to 6%.
07-19-2022 00:35
07-19-2022 00:35
MelissaM535, Please write firmware version now.
It became important.
07-19-2022 00:41
07-19-2022 00:41
After a full charge (100%) i went to settings on the device and restarted it.
I now lasts 5 days without charging!
I've charged it again, so far no problems.
I hope it works for you guys as well, let me know.
07-19-2022 01:02
07-19-2022 01:02
Do you mean update the fitbit app? I did that already.
07-19-2022 03:06
07-19-2022 03:06
Fitbit charge 5 - bateery drain and screen flickering
I am having the same issue - battery is draining quickly and suddenly and also the screen is flickering frequently.
I have tried resetting, restarting, turning off charge 5 gps, disconnecting it via phone and reconneting and all the options have been failed. The watch is not even one year old. I have heard there is going to be an update rolled out to fix this issue but I am not sure when. I wanted to know if there is any fixed date for the update being rolled out in Germany. I got the fitbit charge 5 in Germany.
I contacted fitbit via Twitter but the response was not satisfactory. How can it be possible that customer buys Charge 5 and later fitbit rolls out a corrupt update and blames customer to figure it out. !!
Best Answer07-19-2022 03:33
07-19-2022 03:33
My firmware version is 20001.171.50
07-19-2022 03:48
07-19-2022 03:48
My firmware version is 20001.149.11
Best Answer07-19-2022 04:03
07-19-2022 04:03
Mine is too … I have no idea if it has updated or not? There was no notification on the app of an update?
Best Answer07-19-2022 04:06
07-19-2022 04:06
There are some news of some firmware update rolling out thus afternoon - did anyone start getting it, and if yes - what should it look like in case it reaches your phone (mine is Android)?
Best Answer07-19-2022 04:10
07-19-2022 04:10
I contacted fitbit support via twitter and they responded that they are working on new firmware that will fix our issues. See the conversation below with fitbit support.
07-19-2022 04:13
07-19-2022 04:13
I just installed the update- it brings in the "find my phone" app which is a great addition. Not sure what else, there are very limited info about the update...
Best Answer07-19-2022 05:48
07-19-2022 05:48
Fitbit has rolled out an update. I got one. I hope it will solve the issue.
Best Answer07-19-2022 06:27
07-19-2022 06:27
I am not having a problem since I got my replacement in May. Getting 8+ days on a charge. Should I apply the update?
Best Answer07-19-2022 06:35
07-19-2022 06:35
I’ve had mine for too short a time to be giving advice. My battery performance improved dramatically after the restart. I didn’t notice any further improvement after the update . I am using less than 10% of capacity per day. I believe in keeping my software up to date.
Best Answer07-19-2022 07:02
07-19-2022 07:02
I am going to fully charge and uninstall Fitbit Charge 3 and see if this works for me. Appreciate the update.
