06-21-2024
03:16
05:57
06-21-2024
03:16
05:57
Hi I have recentley aquired a fitbit charge 5. After turning the Gps and Sp02 off and turning off other alerts and always on display, I found the battery lasted over a week.
However, whilst using it in an 11 mile walk yesterday with the GPS and tracking on for around 4 hours the battery had gone down to 34%!
Is that normal for this watch? And if so is it really fit for purpose for longer hikes?
Regards
Ginger
Best Answer06-21-2024 05:59
06-21-2024 05:59
Hi there, @Ginger2320657. Thanks for stopping by in the Fitbit Community Forums and sharing the details about the issue with your Charge 5. I understand your concern, I will do my best to help you!
As a first approach, I'd recommend to follow the recommendations listed in this article to improve or extend battery life. There are a few features that would make the battery drain faster than usual, even in one day. Some of these features are:
If this doesn't apply to you, another step that has been helpful for other users having battery draining problems is the three pulse restart procedure using the charging cable. Nevertheless, since you mentioned you already tried that, please confirm that you performed the restart as described below:
