04-23-2022 06:30
04-23-2022 06:30
I cannot charge my device because it turns off and resets to zero battery every time I try to charge it. It’s become unusable as a result.
04-27-2022
06:47
07:55
04-27-2022
06:47
07:55
Hi, welcome back to the Fitbit Community forums, @Ssk350.
I appreciate all the information you provided about this issue with your Charge 5.
I've been informed that you already contacted the Customer Support team for further assistance with this and it seems they've sent you some instructions. In this case, they will let you know how to proceed.
See you around.
04-28-2022 16:13
04-28-2022 16:13
So, what are the instructions?
04-28-2022 17:21
04-28-2022 17:21
The Fitbit is defective and getting replaced.
05-05-2022
16:31
07:55
05-05-2022
16:31
07:55
Welcome to the Community forums, @DawnVanRiper.
Thank you for sharing that you're having the same inconvenience with the Charge 5.
There are some general recommendations to improve battery life, but since the device is losing battery when connecting to the charger, I would recommend to try a three pulse restart method instead.
If you continue to have the same problem afterwards, please make sure to get in touch with the Customer Support team so they can provide you with the next steps. Click here to get connected
See you around.
