07-17-2024 12:37
07-17-2024 12:37
07-18-2024 04:30
07-18-2024 04:30
Hi there, @RJW51. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that your Charge 5 is not holding a charge. We‘re taking your comments and sentiments in regards to our products and services into consideration.
Even though I truly appreciate you took the time to come here and express your feelings towards your experience with your Charge 5 and also want to find a resolution to your issue, my best advice is to keep the conversation with our Support Team. Note for this kind of inquiries/cases/process, there's not so much we here in the forums can do for you as this is something that our team handles based on our policies.
In my efforts in trying to help you further, as per the description of your post, it could be a sign the contacts need cleaning. Dust and debris can accumulate over time. Clean the charging contacts on the back of your device and the pins on your charging cable using the instructions in How do I clean my Fitbit device?
Nevertheless, bear in mind that as all rechargeable batteries age, they deteriorate to some extent and an older device will need to be charged more often than a new one. The best way of minimizing this effect is to avoid deep discharges of the battery. To maximize the overall life of your Fitbit device's battery, ideally keep it between 20-80%. Many people find that a daily battery boost works best ( e.g. giving it a 15 minutes charge while you are showering in the morning).
Additionally, please find below some tips to best charge Fitbit devices:
For charging purposes, your charging cable or your base station can be plugged into any USB power source, including but not limited to:
If the above doesn't work, please get back in touch with our Support Team. Thanks in advance!
