07-08-2024
06:14
08:37
07-08-2024
06:14
08:37
I looked at my wrist. The screen was black. I out it on the charger assuming it died. It hasn't turned back on since. The button reset doesn't work. Nothing works. Just dead. No glitches or issues before this happened. I purchased a new cable and nothing.
Best Answer07-08-2024 08:42
07-08-2024 08:42
Hi there, @Absnow. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 is still unresponsive. I understand your concern, I will do my best to help you with this!
Please note that sometimes a Fitbit doesn’t seem to be charging when actually the issue is that it has become unresponsive (this can happen if the battery has been allowed to discharge completely). I'd recommend putting it on to charge on a charging wire and outlet known to be working. Leave it on the charger for a good two hours, even if it doesn’t seem to be charging.
When it has had two hours, try restarting your Charge 5. I would recommend trying this maybe twice in a row if a first try doesn’t work.
If the above doesn't work, please see Why isn't my Fitbit device's battery charging?
Best Answer07-08-2024 08:57
07-08-2024 08:57
Thank you for the response. I've tried this multiple times. Leaving it on the charger for hours. Trying to button reset mutliple times and I am getting nothing. I've looked up everything youtube, every similar fitbit community conversation, tried different outlets, boxes, cables and nothing. Any other suggestions before I call in to customer service? I will try this again.
07-08-2024 09:10 - edited 07-08-2024 09:10
@Absnow Since you tried the steps I recommended here and they didnt work, you have a Charge 5 and report experiencing a crashing issue, I need additional information from you that would best be shared privately. I’m sharing a link to a form for you to fill out so we can look into this further.
This form is only meant for you to use, so let me know once you’re done. Click here to get access to it.
Best Answer07-08-2024 09:15
07-08-2024 09:15
I filled out the form.
Best Answer07-10-2024 13:30
07-10-2024 13:30
I received an email asking for information. Then another giving more of the same troubleshooting tips. Will you guys repair or replace my fitbit? What are the next steps?
Thank you
