01-05-2023
12:13
06:13
DavideFitbit
01-05-2023
12:13
06:13
DavideFitbit
Hi, just bought a Charge 5 and went to charge it after a low battery alert. It was not fully out of charge. The screen lit up when connected then it displayed something that looked a bit like a QR code and died. Been on charge for a couple hours but zilch. App cant find it either. Any help given to this newbie would be much appreciated!
06:13
09:58
01-06-2023
06:13
09:58
Hi, welcome back to the Community forums, @Jimbob17..
Thank you for the information provided regarding the issue you're experiencing with your Charge 5.
If this is related to the battery, please make sure that you've followed the steps provided in this article. If the device is charging, but the screen is completely black, make sure that you've also completed the three pulse restart procedure using the charging cable as described here.
I'll be around.
Best Answer01-06-2023 06:42
01-06-2023 06:42
I’m having the same issue. After going through all the troubleshooting steps (screen dim, manual, not tracking oxygen, limit notifications, let it drain completely then fully recharge), my battery now drains in 2-3 days instead on 1. But it’s brand new and not a good product for health tracking if you need to remove it to recharge for hours every 2 days. Is there something else I should try or is mine defective? Seeing there has been a decent amount of activity on this thread I wonder if there were some batches with bad batteries
Best Answer01-06-2023 10:02
01-06-2023 10:02
Thanks David. The first time I did this I connected it to the charger but it wasn’t connected to the mains. I’ve redone it now and it worked - thank you ! 😁
10:49
09:59
01-17-2023
10:49
09:59
@Lizabelle7 Thanks for sharing that your battery is draining in 2 or 3 days.
Before considering other options, please make sure that you've followed the steps provided in this article. In addition, try to perform a restart following the steps listed here below, this has been useful for other users experiencing something similar:
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after one or two days. Keep in mind that some of the feature that can drain the battery more rapidly are:
Let me know if you continue to have the same problem after the the other recommended steps.
@Jimbob17 That's great news! Thanks for sharing this update.
