Charge 5 dies on day 4 with 69-70% charge
My Charge 5 lasts exactly 3 days with normal battery reduction each day. On day 4 with approximately 60-70% battery life, it completely dies and I have to recharge. It’s a brand new Fitbit. Anyone else had this problem?
Moderator edit: format
1 REPLY 1
Hi, thank you for all the information that you've shared about this inconvenience with your Charge 5, @ZeeZee31
Before considering other options, please make sure that you've followed the steps provided in this article to improve battery life in general.
In addition, keep in mind that the team is aware of battery drain issue affecting some Charge 5 devices in which the built-in GPS chip may remain active after ending a GPS-enabled exercise and they've working on an update to fix the issue. In the meantime, it is recommended to try a three pulse restart. Please note the following:
  • If you use GPS to track your exercise, use the Phone GPS setting on your tracker to preserve battery life. For more information, see How do I use GPS on my Fitbit device?
  • We’ll work to resolve it and hope to have a fix soon. Be sure to keep your Fitbit device and app up-to-date to ensure you receive the quickest resolution.
If you already tried all the steps shared in the forums, I recommend that you continue the communication with the Customer Support team for further assistance with this, as not all battery short life problems are related to this specific issue with GPS, but some users do have this problem.
See you around.
