I went for a swim and it only recorded 8min and then turned itself off. Later I was not able to turn it back on and if I plug it into the charger it will keep vibrating (black screen and occasionally the logo) it will only stop vibrating after it is off the charger for a bit . (Fees like that it only stops when the battery drains) I tried resetting like described in another post (3 long button pushes over 8sec) - it done nothing…
Any ideas?
many thanks!
Hi, welcome to the Fitbit Community forums, @OlgaK13.
I appreciate the information provided about this issue with your Charge 5.
I've gone ahead and sent your information to the Customer Support team for further assistance, so you should be getting a reply soon. Please keep an eye on your inbox.
See you around in the Community.
