01-16-2022 16:31
01-16-2022 16:31
I got my device yesterday. Just did my first workout. It didn't buzz as I changed from the different heart zones. I had to keep checking it, which is annoying. All notifications are on. How do I fix this?
Best Answer01-16-2022 16:39 - edited 01-16-2022 16:45
Hello @Panda1996
On your Charge 5 scroll down from the Clock Face screen to Settings, tap then scroll up to Heart Rate Zone Notifications and switch it to on. Make sure the Heart Rate is set to on too.
That should make your notifications come on.
I hope that helps.
Best Answer01-16-2022 17:04
01-16-2022 17:04
Both are on already.
Best Answer01-16-2022 17:28 - edited 01-16-2022 17:28
Are the Heart Zone Notifications set on in your Workout Shortcuts on your Charge 5 too? Press Start and swipe up to check. Sometimes they’re turned off.
I hope that helps.
