11-14-2022
12:39
19:26
DavideFitbit
11-14-2022
12:39
19:26
DavideFitbit
The title says recently my Charge 5 started dying in about 1 hour. I've tried the troubleshooting tips on other post but with no luck. I've had issues with the battery before but it was never this bad. And usually resetting would help. Not this time. I got the thing in January. I don't what caused it to start draining so fast.
Moderator edit: format.
11-15-2022
19:26
06:25
11-15-2022
19:26
06:25
Hi, welcome to the Fitbit Community forums, @Jpaul87.
I appreciate all this information that you've shared about the inconvenience that you've been having with your Charge 5 and the troubleshooting steps that you already tried.
In addition to performing a three pulse restart using the charging cable, let me know if you've also followed the steps provided in this article to improve battery life in general.
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after one or two days. Keep in mind that some of the feature that can drain the battery more rapidly are:
Let me know if you continue to experience the same inconvenience after all these steps.
I'll be around.
Best Answer11-15-2022 19:50 - edited 11-16-2022 06:47
Best Answer11-16-2022 06:50
11-16-2022 06:50
I just fully charged again and within 10 minutes it's down 20%
Best Answer11-16-2022 09:36
11-16-2022 09:36
Ultimately the charge 5 is a defective product the battery drain issue was supposedly fixed with the 30th July software update 7 months after they told us they where working on an update. It did actually make an improvement and I have seen my Fitbit last a full week. It does still randomly drain I find that doing a restart over and over and over again eventually will improve it for a while.
Although I still can’t find a way to get it to sync to my phone without it taking half an hour.
I won’t be buying a Fitbit again
11-16-2022 16:28
11-16-2022 16:28
Having the same problem. This seems like a faulty device. Can I open a warranty claim,
Best Answer11-16-2022 17:16
11-16-2022 17:16
I just contacted the chat support and they offered a replacement. I hope the replacement is not as bad
10:30
06:23
12-01-2022
10:30
06:23
Hi everyone, and thanks for sharing all these updates and for confirming that you already tried all the steps suggested earlier.
It seems that some users have already contacted the Support team for further assistance with this. If you haven't done so already and if you already tried all the steps mentioned earlier, I do recommend that you continue the communication with the Customer Support team so they can let you know how to proceed or what options are available for you. You can get in touch with them here.
Thank you for taking the time to share all your feedback about this as well, all your comments regarding this inconvenience are greatly appreciated.
