Charge 5 gave me 54,661 steps May 1, 2022 at 320am.
ANSWERED
Charge 5 gave me 54,661 steps May 1, 2022 at 320am. How can I delete those steps that occurred while sleeping since they badly distort the data for the day, week and month  (fixed see my reply added)  my fix reply was vague. If you also have Fitbit app on pc open dashboard, select log at top, select Activities..at bottom of page there is Log Activities. Type in driving ..enter it at then put the start time that matches the time of the spike and a duration of 10 minutes  enter. That removed it from the log
1 BEST ANSWER
Accepted Solutions
guess my fix reply was vague. If you also have Fitbit app on pc open dashboard, select log at top, select Activities..at bottom of page there is Log Activities. Type in driving ..enter it at then put the start time that matches the time of the spike and a duration of 10 minutes  enter. That removed it from the log
4 REPLIES 4
Fixed it.. had to go to activities and log a driving activity for 10 minutes and the time of the steps spike.
Same thing happened to me. It buzzed my fitbit saying I had 24,000 steps around the same time.  However, im not understanding your fix.  You said after the fix your steps spiked?
Well, it worked. Not sure how you came up with that fix, but im good now.  Ty so much for the help!
