08-15-2022 19:17
08-15-2022 19:17
Charge 5 has blue/green square no display?
Best Answer08-16-2022 02:04
08-16-2022 02:04
Hello @dandaman82
Have you tried to restart the Charge 5 ?
Best Answer01-21-2023 08:40
01-21-2023 08:40
My charger doesn't have a flat end.
Best Answer01-21-2023 09:52
01-21-2023 09:52
You need to use the charging cable that came with your Fitbit. Look at the USB end of the charging cable. You should see a small button on one side. That is what you need to press to reset/restart your Fitbit.
Best Answer01-21-2023 09:56
01-21-2023 09:56
That reset doesn't do anything. I talked to FitBit customer service. Seems I have a bricked unit.
Best Answer01-21-2023 10:14
01-21-2023 10:14
Apparently, many of us have experienced issues such as unresponsive screen and sudden loss of battery power after installing the latest firmware update.
Thankfully, my Charge 5 was still under warranty and my replacement arrived a couple of days ago. So far, my replacement is working fine even after updating the firmware.
