12-12-2021
21:00
14:22
LizzyFitbit
12-12-2021
21:00
14:22
LizzyFitbit
Hi, today I bought the Fitbit Charge 5 specifically for the heart rate alert. My doctor wants me to stop all activities, if my heart rate goes outside a certain range.
I tested it with my pulse oximeter and confirmed the heart rate meter was accurate, then set the alert accordingly. But while I was making dinner, the watch face showed I was well above range, yet the alert did not go off.
I've tested the countdown timer and it works (I assume it gives the same sort of alert)??
Any ideas on why I didn't get a heart rate alert??
Best Answer12-13-2021 14:31
12-13-2021 14:31
Hi @TreasureTracker. It's good to see you here.
Thanks for the detailed information, and your efforts while working on this matter. I understand how important these heart rate notifications are for you and just to confirm, did you follow the steps described here to enable them? If that's correct, please give a try to the following steps and monitor your tracker's behavior in the next days:
Hope this helps.
