01-27-2025
01:27
03:58
01-27-2025
01:27
03:58
I've had the Charge 5 issues. I've tried everything I could think of and every suggestion I've seen from clock faces to forced starts. I've installed the device, the app, every Bluetooth connection (restoring only the charge) but it still reliably crashes when I sync with my phone (IOS App). I have to keep device wired to sync. i am open for solution beyond reset or clock face change etc.
Best Answer01-27-2025 04:01 - edited 01-31-2025 10:52
Hi there, @Kiranacharya76. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 is crashing when syncing. I understand your concern, I will do my best to help you with this!
As our last resort, I'd recommend performing a factory reset on your Charge 5. Important: Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
With the above being said, please sync your Luxe and then, proceed with the steps below in the order listed:
You can follow the steps to set up the device after that How do I set up my Fit-bit device?
Best Answer01-30-2025 23:41
01-30-2025 23:41
Hi, Thanks for suggestion; however this didnt work. i reset device as well as reinstall Mobile app on my iPhone as well; however nothing worked. it is still switching off as soon as i sync with mobile app. Is there anything else that i can try?
Best Answer01-31-2025 10:53
01-31-2025 10:53
@Kiranacharya76 You're very welcome! Since all the steps you tried didn't work, you have a Charge 5 and report it's not working properly, I need additional information from you that would best be shared privately. I’m sharing a link to a form for you to fill out so we can look into this further.
This form is only meant for you to use, so let me know once you’re done. Click here to get access to it.
01-31-2025 20:22
01-31-2025 20:22
