10-04-2021
19:41
10:23
SilviaFitbit
10-04-2021
19:41
10:23
SilviaFitbit
My Charge 5 is giving me an "Active Call" notification every 1-2 minutes while I am on a call. It JUST started doing this, and it is driving me crazy. I've looked through everything in the app, and I can't find a way to shut it down. Help??
10-06-2021 10:31
10-06-2021 10:31
@Bain Hi there. Thanks for the details mentioned and the research performed prior to posting.
I see where you're coming from. Let's try the following troubleshooting:
- Force quit the Fitbit app
- Reset Bluetooth
- Reset system notifications
- Restart your Charge 5
- Refresh notifications
- Set them up again
All the instructions can be found on this article.
Hope this helps.
Best Answer10-06-2021 11:28
10-06-2021 11:28
The article does not explain the steps you outlined.
"Reset bluetooth." Does this mean turn it off, and then turn it on again? Because I have already tried that. Please explain?
"Reset system notifications." There is no topic for this in the article. I don't know what this means. Same with "refresh notifications" and "set them up again." Can you please explain what you mean by these steps?
I never set up notifications, and I sure as heck never, ever told FitBit to remind me that I'm on the phone every 1-2 minutes. (I do not need ANY notification multiple times. I received approx. 30 identical notifications during a single phone call!)
I do NOT want to stop receiving all notifications. I DO WANT to stop receiving ANY notification that I am actively on a phone call. (This is a dumb "feature" by the way--I do not need to be reminded every 1-2 minutes that I have an active phone call, while I am actively participating in the active phone call.)
10-06-2021 13:14
10-06-2021 13:14
That doesn't work, and looks like this is a problem on other devices besides the Charge 5. Is that correct?
This is driving me crazy as well so I had to just turn off Call Notifications totally. But that can't be the solution, I really do need to have the calls notify me when it comes in, i just don't need it reminding me every minute that i am on a call...
Is there anything else that can be done?
10-06-2021 13:17
10-06-2021 13:17
How did you turn off the call notifications? I can get behind that as a temporary fix. (I looked through the app and couldn't find anything that seemed relevant.)
Best Answer10-06-2021 18:45
10-06-2021 18:45
Select the charge 5 from the main page where you can log out of the app, then click the “notifications” tab from the next page. Then deselect the phone call button.
06-02-2022 16:49
06-02-2022 16:49
I had the same problem as Bain. It was also driving me nuts. Thanks mkerr6!
