01-23-2025
10:07
10:37
EstuardoFitbit
01-23-2025
10:07
10:37
EstuardoFitbit
I've had my charge 5 for 3 years. Lately the battery is starting to struggle a bit. Yesterday went for a swim and now it doesn't charge, it just vibrates when I plug it in and there's a flashing white line on the screen. Anything I can do?
Welcome to the Fitbit community forums, @SunsetRunner.
Thank you for confirming that you're having the inconvenience with the Charge 5.
Could you please provide a few more details about the issue? In the meantime, please make sure that you've followed the steps provided in this article. If the device is charging, but the screen is completely black, make sure that you've also completed the three pulse restart procedure described here.
Best AnswerI tried the restart procedure. The screen seems working at first, fitbit logo and loading screen appear but the device isn't charging. It remains at 0% even after some minutes. Then screen goes black, it restarts but still 0%.
Hey there @SunsetRunner, welcome to the Fitbit Community.
I just noticed that the link I shared before for the recommended steps was corrupted.
Have you had a chance to try the recommended steps, or were you unable to do so? I will share the link once again. Please let me know how it goes.
Best AnswerHi yes I tried but still not working. I left it under charge for more than one hour, it got to 1 or 2% but then again it restarts and it's back at 0%. Synch works, it shows today's date even though on the app it says battery is at 60%.
Thanks a lot @SunsetRunner, for the confirmation!
In this case and after following this workflow, the next immediate step will be to create a case with support.
Please take a moment to fill out this form. It will help my team to assist you better. Let me know once you've submitted it so I can keep you in the loop.
I have the exact same problem. Did a spin class and just drained to critical battery and then shut down. Tried all the steps and nothing works. It gets to 2% and the nothing. remove from charger and goes blank.
