10-03-2023
09:21
09:54
10-03-2023
09:21
09:54
Does anyone know if the Pool Length feature still works using the new App, mine seems to not record them now, only distance which is not as useful.
10-03-2023 10:16 - edited 10-06-2023 06:43
Hi there, @BobofBurton. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post. I'll be glad to help you.
Yes, it should work as normal. To better assist you, may I know if you're not seeing your pool length on your Charge 5 or the Fitbit app? or both?
Meanwhile, please check this help article How do I set the pool length for my Fitbit device?
Best Answer10-04-2023 02:03
10-04-2023 02:03
10-09-2023 03:26
10-09-2023 03:26
I have checked the Charge 5 settings and it is set to record pool length of 25m however the App still does not show this detail. Has it been removed from the new App, if so it is a backward step.
