11-17-2024
01:01
10:50
11-17-2024
01:01
10:50
Fitbit charge 5 shows 0 steps but the app shows 6590 steps. Mobile tracker is off. Why is that?
Best Answer11-18-2024 10:51
11-18-2024 10:51
Hi there, @LenSav. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that the your Charge 5 is not showing your steps. I will do my best to help you with this!
If you haven't done so yet, please try the steps below:
If the above doesn't work, please restart your Fitbit device as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best Answer11-18-2024 13:41
11-18-2024 13:41
Thanks, but none of these worked. E.g Wednesday shows 10k steps and 7km. Thursday shows the same number of steps exactly, although I didn't walk, but 0 km. Any other ideas?
Best Answer11-18-2024 13:43
11-18-2024 13:43
...and I labelled your answer as best by mistake
Best Answer11-19-2024 13:12
11-19-2024 13:12
Hello @LenSav
I removed the Best Answer from the Moderator's post based on your reply.
