11-03-2021
07:24
13:39
ManuFitbit
11-03-2021
07:24
13:39
ManuFitbit
everything was fine yesterday, today: no zone minutes or heart rate.
Bluetooth is on.
Steps, distance and calorie are recording.
what's up?
Moderator edit: clarified subject.
Best Answer11-03-2021 08:13
11-03-2021 08:13
Hi, @dlthomsen, welcome to the community, check your HR is switched on, you may have inadvertently turned it off. Swipe down from the clock face> touch "settings"> Swipe up three tiles to "Heart Rate", the slider should be to the right and not greyed out. Swipe right and up to return to the clock face. You may be interested in this article How do I track heart rate with my Fitbit device? Let us know how you get on.
Cheers
Gr4ndp4 | UK
03-27-2022 13:32
03-27-2022 13:32
HR is on. Missed out on 145 active mins with my bike ride today. So annoying!! If I don’t do a restart every day, it seems my Charge 5 misses all sorts of data. Sometimes it’s my sleep and today, my active minutes. Not cool not to mention Super Frustrating!!!
03-27-2022 13:42
03-27-2022 13:42
Is there any way to edit my zone minutes to the correct amount to capture those that are missing?
03-29-2022 09:31
03-29-2022 09:31
Same here. My fitbit is not tracking my sleep data and zone mins since yesterday.
03-29-2022 10:03
03-29-2022 10:03
04-14-2022 14:07
04-14-2022 14:07
I have been having issues with zone minutes even when charged well over 35%. Frustrating.
05-15-2022 01:43
05-15-2022 01:43
Hello,
i have tge same problem with my charfe 5. For the last three days all data would sync but active minutes are missing. They are recorded bt the watch but do not appaear on the app or on the web deashboard.
I have restarted phone, log off/log on, switch on/off bluetooth/ same for wifi ...
Someone know how to fix this ? I like fitbit but this data issue start to be really ennoying
05-16-2022 08:08
05-16-2022 08:08
Exactly the same for my Charge 5. Had no issues at all with my previous Fitbit - a Charge 2! So frustrating. Mine is currently at well over 35% charge.
05-16-2022 12:20
05-16-2022 12:20
Best Answer05-24-2022 16:22
05-24-2022 16:22
Me too 5/24/22
Best Answer05-24-2022 16:33
05-24-2022 16:33
05-24-2022 17:53
05-24-2022 17:53
90 days warranty? Perhaps this is the reason my blood oxygen saturation (SPo2) graph no longer shows as well as the ♥️ symbol on my Charge 5 for a 30 seconds check up!
Best Answer05-31-2023 09:36
05-31-2023 09:36
I am new to this thread but have all the same issues. I bought my Fitbit 4 months ago and it no longer tracks active minutes or heart rate. I have always used a Fitbit but this device is frustrating.
Best Answer05-31-2023 10:56
05-31-2023 10:56
Hi & welcome @wilcoxson1 ,
Sorry to hear that you are having issues with your Fitbit. If you haven't already done so, I suggest restarting your device. You can do it from the Settings menu on your Charge 5 or by using the charging cable that came with your tracker. Hopefully, this will fix your issue. You can click on this link for more detailed instructions: How to update, restart, and erase on the Charge 5
BTW, I found that sometimes it takes several restarts to get the device back to normal operation.
