Charge 5 is not tracking my distance
Hi
My charge 5 is not tracking my distance even though the app shows distance covered for the day. I've restarted the device, made sure location is a permission on the app, tried syncing the device and app nothing appears to work. I've seen replied about stride length, I've never had to set a stride length so don't think this is the issue either. Any ideas on why the device has stopped tracking?
1 REPLY 1
"I've never had to set a stride length so don't think this is the issue either."
Still worth trying.  There is an explanation why it worked for some - not worth getting into, if it works.  Just reset it to the default, or same value.  Not that much wasted effort if it doesn't work.
