05-27-2023
02:37
20:49
EstuardoFitbit
05-27-2023
02:37
20:49
EstuardoFitbit
My sleep is tracked with several interruptions during the night. The recordings are also incorrect as awake periods are missing.
Best Answer05-27-2023 04:36
05-27-2023 04:36
Hi there, @jonaf. Thanks for stopping by in the Fitbit Community Forums and sharing the details about the issue with your Charge 5.
While reading your post I was wondering if your Charge 5 is brand new? If so, please note since you just bought it, give the RHR a few days to settle down. It does some calculations, looking at heart rate throughout the day and while you are sleeping, so it might just not have enough data to give a reasonable value yet.
In addition to that, I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
05-27-2023 04:36
05-27-2023 04:36
05-29-2023 06:07
05-29-2023 06:07
My fit bit charge 5 was recording sleep consistently up until the last 2-3 weeks.
I am now just getting partial sleep or no recordings at all.
Have done all the suggested fixes but still not recording my sleep consistently.
I will cancel my subscription if I continue to have problems
Best Answer06-05-2023 05:35
06-05-2023 05:35
My Fitbit charge 5 has rarely gotten the sleep right. Ex. Says I slept 55 min last night when I slept a good 7 hours. Have had this problem from the beginning.
Best Answer06-06-2023 07:21
06-06-2023 07:21
Tried everything fiibit recommended. Nothing has worked
Best Answer06-09-2023 05:38
06-09-2023 05:38
My Fitbit recorded sleep yesterday but did not today. Very erratic
