08-04-2023
09:02
09:57
08-04-2023
09:02
09:57
My Charge 5 stopped giving sleep stages in about May 2023. I have tried everything listed in the many posts about the same problem. Nothing has fixed it. Occasionally it will work for one night then is back off the following night.
I spoke to customer service & was told it should be replaced so I bought a new one. The new one also didn't work. They sent a replacement for the new one which also did not work.
Cannot get any resolution or repair. Can anyone suggest a different tracker that will accurately keep track of sleep patterns,stages, etc. ??
08-04-2023 09:58
08-04-2023 09:58
Hi there, @TA3045. Welcome to the Fitbit Communtiy Forums. We‘re taking your comments and sentiments in regards to our products and services into consideration.
If you're missing just your sleep data, I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
08-04-2023 10:04
08-04-2023 10:04
As noted, i have tried all of these "recommendations". Nothing fixes the problems. I think the issue is a problem with monitoring heart rate. Must be something going on in the transition between Fitbit & Google.
Best Answer08-06-2023 03:30
08-06-2023 03:30
Having the same problem but it’s been since the 3.86 update in July. I have an iPhone 14 pro & pay for Fitbit premium. I’ve been a Fitbit owner since 2016 & know all the “tricks” that you are supposed to do when not getting a sleep score. So frustrating & annoying
Best Answer08-06-2023 07:39
08-06-2023 07:39
Fitbit has to know there is a problem, but they don't seem to care enough to fix it or acknowledge the problem. Very frustrating.
It worked well for me for years & then suddenly stopped. And they offer virtually no assistance (other than the same "tricks" that do not work).
