02-15-2022 18:46
02-15-2022 18:46
Charge 5 is stuck in the middle of an update
Best Answer02-15-2022 19:16
02-15-2022 19:16
Hello @Psvoboda1958
It might be worth putting it on the charger and then pressing the button at the USB end 3 times to restart it. Then you could try again.
Are you using iPhone or Android? That could make a difference.
If you have an ad blocker on your phone it’s worth disabling it while you’re trying to update.
I hope that helps a bit.
Best Answer02-16-2022 02:37
02-16-2022 02:37
Yep, same here, so stupid! And completely dead now!
Best Answer02-16-2022 02:38
02-16-2022 02:38
02-16-2022 02:38
I tried that a hundred times already in the last hour, didn't work! So stupid!
Best Answer02-16-2022 02:40
02-16-2022 02:40
I tried all that, basically, the charge 5 is not responding at all, All dead! But thanks for your respond! 😘
