02-17-2024
06:26
04:19
02-17-2024
06:26
04:19
My fitbit is tracking miles/steps/ etc while I’m not wearing it?
Best Answer02-17-2024 09:30
02-17-2024 09:30
Hi, @Otis1010 welcome to the community, my theory is that if you put your charge 5 down on a reflective surface the green LED is detected and we get these "Ghost" readings. Next time you take it off put it face down, the LED should stop flashing. A couple of more points, you can delete the suspicious data (if you want to) How do I add, edit, or delete Fitbit data and activities? - Fitbit Help Center explains the process. I would encourage you to wear your Charge 5 any time it's not charging, if, for instance, you sleep without it on you'll not get the all-important sleep stats.
I hope this helps but if you are still stuck please post here again.
Cheers
Gr4ndp4 | UK
Best Answer02-18-2024 01:24
02-18-2024 01:24
Mine seems to double - or more than that - my steps perhaps when I’m wearing the watch and carrying phone - maybe it’s tripling as l also have google (gmail) - whatever it is doing l can never trust the steps, so use primarily to monitor my sleep only, which I need having sleep apnoea!
Best Answer02-18-2024 13:42 - edited 02-18-2024 13:44
Hello @DramaQueen58
If you're seeing double the number of steps when you are wearing your Fitbit & carrying your phone, that sounds to me like you have your phone added to your Fitbit app as a tracker.
To check:
If you see you phone, you should tap on it and tap on Disconnect device on the following Phone page. Tap to confirm disconnecting your phone from the app.
The option to add your phone as a Connected device is for when you want to track your steps when you're not wearing your Fitbit. You don't need to have your phone connected for normal use.
02-18-2024 13:50
02-18-2024 13:50
