02-07-2025
08:54
05:08
02-07-2025
08:54
05:08
How do I fix what notifications come through to my Fitbit? Everything was fine only showing SMS texts, calls and calendar reminders until I updated the app and now EVERYTHING is going to my Fitbit.
Even if I have the notifications switched off, only have select ones turned on and others off, it still ALL comes through. I don't want it on DND, I just want certain notifications.
How can I fix this?
02-08-2025 05:10
02-08-2025 05:10
Hi there, @Spj04. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 is still receiving notifications you don't want. I understand your concern, I will do my best to help you with this!
Since the issue persists, please try the following:
02-08-2025 08:38
02-08-2025 08:38
Now no notifications will go through at all. I've done everything mentioned multiple times and nothing is working. Whether I only have a few selected or everything, nothing goes to my fit bit.
Best Answer02-22-2025 22:07
02-22-2025 22:07
Now no notifications will go through at all. I've done everything mentioned multiple times and nothing is working. Whether I only have a few selected or everything, nothing goes to my fit bit now after what you said to try.
Best Answer02-23-2025 02:41
02-23-2025 02:41
I'm having exactly the same issue. I get every notification my phone has, or nothing. I don't want my wrist to tell me that a newspaper headline has popped up on my phone.
