Hi @kstande. It's good to see you here in the forums.
Thanks for the details shared in your post and for restarting your Charge prior posting. I suggest trying a factory reset by doing these steps:
If it continues doing the same, my best recommendation is to contact our Support Team so they can look deeper into the issue and help you with this matter. Click here to get connected. Make sure to mention the steps you've followed, so they can help you from there.
Catch you later.
Best AnswerHello @kstande
Since a factory reset will wipe out all your data, you will want to sync your Charge 5 and your Fitbit app first before attempting a factory reset. Otherwise, you will lose all your data in your Charge 5.
Best AnswerStill able to restart by charging. But issue of black screen recurs—have tried multiple fixes as suggested on this site including removing and reinstalling device. Each works until it doesn’t. Very frustrating and lost data (especially sleep)
