07-04-2023
08:04
08:39
07-04-2023
08:04
08:39
My charge five screen goes black and won’t turn on. I restart with the cable. Battery shows 100%. Within a minute it turns off again and screen goes black and won’t go back on.
07-04-2023 08:43
07-04-2023 08:43
Hi there, @Cottageboy. Welcome to the Fitbit Community Forums.
As a first approach, please make sure you've restarted your Charge 5 as described here.
If the restart doesn't work and your Charge 5 doesn't vibrate during the restart process, please follow the steps below:
07-04-2023 09:06 - edited 07-04-2023 12:52
Hello & welcome @Cottageboy
Sorry to see you're having problems with your Fitbit.
A troubleshooting step you can try is changing the clock face. Sometimes this process will get your Fitbit "unstuck" so it works properly. From what I read, it may take several attempts at changing clock face and/or restarting your Fitbit to get the screen to respond & stay on. If you're successful, you can change the clock face back to the one you prefer. Click here for instructions on: How to change Charge 5 clock face
If these steps don't work, I recommend that you contact Fitbit support. They will likely walk you through the same troubleshooting steps. Once they confirm that the troubleshooting doesn't return your device back to normal operation and if it's still under warranty, they should send you an offer to replace the tracker/pebble or a discount on a different device. If your Fitbit is out of warranty, they should offer a discount on a replacement. Note: the discount is on the full price of the device, even if it's on sale in the Fitbit store. Click here for: Fitbit support
07-04-2023 10:17
07-04-2023 10:17
