04-04-2024
02:13
06:27
04-04-2024
02:13
06:27
My fitbit charge os waking at 4:50am every day. No alarm is set for today and it woke me on a day off. It is very maddening
Best Answer04-05-2024 06:43
04-05-2024 06:43
Hi there, @MaineGemini. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I understand where your concern is coming from. I will do my best to help you with this!
By any chance, did you see any message on the screen while it was vibrating? If there was a "Look Alive" message, please note it is part of your alarms and it seems like you have the Smart Wake feature enabled. Smart Wake attempts to find the best time to wake you starting 30 minutes before the alarm time you set. For more information, see How do I set an alarm on my Fitbit device?
If the above doesn't describe your issue, I know that you mentioned that you don't own Alexa, but please note I've seen some cases very similar to yours when it results in Alexa being the one making these alarms going off at the wrong time. So, please note that this might also be Alexa alarms. Know that the alarms and timers you set with Alexa are separate from those you set in the Alarms app. For more information, see How do I use a voice assistant on my Fitbit smartwatch?
Nevertheless, if none of the above helps, please try restarting your Charge 5 and see how it behaves the next morning at 4:50 AM.
