03-02-2024 02:04
03-02-2024 02:04
For no apparent reason, I am no longer seeing a heartbeat score. Checked with online chat, reset as advised. Still no heartbeat score and still no green light on the back. Anyone experienced the same or similar problems and got a solution?
Best Answer03-02-2024 07:54
03-02-2024 07:54
Hi, @NevilleCharge5, welcome to the community, may I suggest you review the HR setting on your Charge 5 From the clock screen swipe down to "Settings" then swipe up to "Heart Rate", make sure the slider is in the "On" Position. The green LED should flash for a few seconds as it seeks your pulse on your skin. If it's off your wrist pick it up and place a finger over the LED or place the Charge 5 against your wrist. I assume you have not recently had a Tattoo on the wrist or developed scar tissue that will stop the HR LED/sensor array from working.
I hope this helps, let us know how you get on.
Cheers
Gr4ndp4 | UK
03-05-2024 06:06
03-05-2024 06:06
Thanks.
I also got this info in an email from the Fitbit team (and it worked):
It's a real pleasure to continue helping you via email regarding the situation with your Fitbit not working the heart rate.
Then open the Fitbit app on your phone and setup.
Then tap Devices
Best Answer03-05-2024 14:57
03-05-2024 14:57
Hello @NevilleCharge5
Thank you for letting us know that the instructions that support gave you worked.
If this happens again or for any other user who is going to use the instructions, please do a sync first. If a sync isn't done first, then any data that wasn't synced to the Fitbit app will be lost. "Clear User Data" is the equivalent of doing a factory reset and removes all your data from the device.
