08-10-2023 01:53
08-10-2023 01:53
A week ago my Charge 5 stopped reporting Health Stats & Sleep, also my heart rate reading went off for a day and then came back with a ridiculously high reading for a while, then it disappeared and has not returned. The only thing recording over the past week is steps.
My fitbit is only 12 months old.
I have tried everything i can think of and all suggestion to reset & I have uninstalled and reinstalled App. I am at a loss as to how to fix
Any suggestions please.
08-10-2023 03:31
08-10-2023 03:31
Welcome back to the Fitbit community, @Muppet2!
Sad to hear that you're having issues with your Charge 5. Thanks for having tried to fix those yourself.
Please try to have a peek on the underside of your device while wearing it to see if the LEDs for HR tracking are blinking. If so I'd suggest to try if cleaning the back of your Charge 5 will your issues.
How do I clean my Fitbit device?
I'll keep my fingers crossed.
08-10-2023 05:34
08-10-2023 05:34
I have checked and no LED blinking 🙀
Is there anything i can do?
08-10-2023 06:02 - edited 08-10-2023 06:02
Thanks for reporting back, @Muppet2.
Please check if HR tracking is set to ON. To do so, swipe down from the clock screen and tap the Settings app to open it. Then go to Other Settings and locate Heart Rate. If it' set to OFF turn it on. If it's already ON, turn it OFF and ON again.
08-10-2023 06:14
08-10-2023 06:14
Thank you
I have done this many times over the past week
I have also tried rebooting from the usb lead button
08-10-2023 08:44
08-10-2023 08:44
Thank you but still Not working
Is there anything else i can try?
08-10-2023 09:45
08-10-2023 09:45
@Muppet2 , although you've mentioned already having tried several things to get your Charge 5 fixed, I'd suggest to see if restarting your device will have a positive effect, especially as this procedure sometimes needs more than one attempt to work. Please do so following these instructions as timing is very crucial:
1.) Connect your Charge 5 to the charging cable which has to be connected to a reliable power source.
2.) Press the button located on the flat end of the charging cable 3 times within 8 seconds(!), holding each press for about 1 second(!).
3.) Wait around 10 seconds until the Fitbit logo appears on your device's display.
08-10-2023 11:31
08-10-2023 11:31
i have tried that procedure a few times and it has not worked
08-10-2023 11:43
08-10-2023 11:43
Sad to hear, @Muppet2. I'd now contact Fitbit support as soon as possible for further assistance as you've mentioned that your device is around 12 months old:
08-10-2023 13:28
08-10-2023 13:28
Thank you for your help
08-10-2023 13:44
08-10-2023 13:44
You're welcome, @Muppet2.
