Hey guys, wondering if anyone else is having this issue or has a resolution.
My phone updated the Fitbit app on 4/19 and since then I have not been able to sync any data (sleep, steps, zone minutes etc) onto the phone. I deleted and reinstalled the app as well as restart the Charge 5 but nothing seems to be working.
The Charge 5 is working and tracking. It just does not seem to sync. The sync bar moves across the screen like it is syncing, but nothing happens after.
Thanks in advance!
I same your problem.
I before unknown is Fitbit Apps problem, i hard reset my watch, after to confirm search my charge 5, but cannot open verify code on the charge 5, Fitbit Apps will show cannot connect charge 5, and please check your Battery, Bluetooth, Usb to restart, return to connect device page repeat to setup.
Best AnswerSorry, i try reset with the USB, every cannot to fix problem
So, after hard reset my Charge 5 haven't fix connection problem.
Best AnswerSince yesterday my Charge5 won't sync anymore, no matter how often I restart the device. And I don't get text messages on my device anymore either. Any advice please?
Update: after a chat with support I force closed the Fitbit app, turned off Bluetooth, waited 10 seconds, and turned back on, all while my device was on the charger . After that, it started to sync again.
