12-08-2022 05:10
12-08-2022 05:10
I start my charge 5 when beginning a bike ride and close and save when done.
Every other day, it will not record any kms but does record the time and active minutes/calories burned etc. On other days it records everything fine.
Can I fix this?
Best Answer12-08-2022 14:42 - edited 12-08-2022 14:43
@ChrissieBudd I assume this is an outdoor bicycle and you're using GPS? Are you using the Charge 5 GPS, or Dynamic GPS mode, which will look for a GPS signal on your mobile device? Since you're getting distance (and maps???), I assume the GPS is turned no for the bike activities in your settings.
One thing to try is to make sure you see the Fitbit has a GPS connection before you starting cycling.
https://help.fitbit.com/articles/en_US/Help_article/1874.htm
CharlesKn | Mid-Atlantic, USA
60+, strength and cardio
Charge 5, Android, Windows
Best Answer12-09-2022 00:12
12-09-2022 00:12
Yes, outdoors.
it’s on dynamic and my phone is always in my jacket 🧐
I’ll wait for the gps to connect before I set off in future.
thank you
