07-06-2024 06:33
07-06-2024 06:33
Hi my charge 5 is not charging. It was at 1% I put it on the cradle but it’s not responding nor charging. I have tried cleaning the back and pins, the restart button procedure 20 times and it’s not woken up again
07-06-2024 08:33
07-06-2024 08:33
Hi, @AleNM, welcome to the community, you may find this article is of interest Why isn't my Fitbit device's battery charging? - Fitbit Help Center I apologise if you have already seen this. If you have explored these options in detail & verified you are using a live USB port for at least 60 minutes but are still without progress, (I note you've tried a restart) you should contact Customer Support via the Fitbit app on your phone.
I hope this helps.
Cheers
Gr4ndp4 | UK
07-06-2024 10:06
07-06-2024 10:06
I have been trying but the chat is not working and there is only a UK number
07-06-2024 10:19
07-06-2024 10:19
Hi, @AleNM, are you in the UK? If not there's a slot at the bottom of the screen to change your location. The Help process has been updated recently and I'm not sure how it progresses now.
Cheers
Gr4ndp4 | UK
