07-20-2022
09:56
06:16
EstuardoFitbit
07-20-2022
09:56
06:16
EstuardoFitbit
I recently (past 1-2 months) found that my Charge 5 wouldn't sync consistently. Whenever I tried to sync manually, it always timed out. It would only sync randomly on its own--I would just open the app and see updated numbers. It became a larger problem when the sporadic syncing became less and less frequent. I tried all the troubleshooting steps: reset the Charge 5, restarted my phone, turned off/on bluetooth, uninstalled/reinstalled the app, deleted the device from my app and tried to re-add it. Now when I try to set up my device again, the fitbit app is able to find the Charge 5 (it's stuck on the "Found it!" page) but not connect (the bar at the bottom says "connecting" until the error screen pops up). The wheel just spins until it times out and has me start over. I'm about to quit Fitbit altogether if this doesn't get sorted out. Super frustrating that it won't stay connected and synced. Help?
07-20-2022 19:10
07-20-2022 19:10
Welcome to the Fitbit Community, @EMH206.
I’m sorry to hear about the difficulties you experienced with your Fitbit Charge 5. Thank you for trying to get them resolved before contacting us.
I noticed that you've been in touch with Customer Support. I'm pretty sure they've done their best to provide a high level of support. Thank you for your patience while dealing with this situation.
Have a nice day.
