05-15-2022
03:19
10:42
DavideFitbit
05-15-2022
03:19
10:42
DavideFitbit
I have a new Charge 5 that I purchased at Walmart in the US. I am not there now and have no way of replacing it. It is less than a year old. I also have a Versa 2 on which the button you push in seems to be jammed. This is my 5th Fit Bit. I have always been very satisfied until my experience with this Charge 5. All I see on the screen now are 2 red dots!
10:41
07:26
05-18-2022
10:41
07:26
Hi, I appreciate the information provided about this issue with your Charge 5, @Gunner25.
If you haven't done so already, could you please confirm if you already tried the three pulse restart method using the charging cable?
In addition, you can also try changing to a different clock face if you continue to experience the same problem.
Hope this helps, I'll be around.
05-18-2022 21:25
05-18-2022 21:25
I had the same problem. This fixed it.
Best Answer05-19-2022 06:38
05-19-2022 06:38
I have the same issue but it is not fixed.
Best Answer05-19-2022 07:20 - edited 05-19-2022 07:23
Stopped responding last night and the battery wasn’t dead. Updated tracker this morning and the screen is black. Tried resetting from the charging cable multiple times and hasn’t fixed the problem.
There is a vibration after each push of the button and one about 2 seconds after the third push. The logo never appears.
05-19-2022 07:59
05-19-2022 07:59
I have the same issue - I have done the charge cable reboot already; my Charge 5 is still not responding. I cannot update the clock face - my phone says it cannot connect to the device and the battery is dead. It does not not appear to be charging or responding to charge cable input.
Best Answer05-19-2022 09:45
05-19-2022 09:45
You may need to let it charge for quite awhile before attempting the reset. The first time mine died (due to the mysterious battery drain issue: https://community.fitbit.com/t5/Charge-5/Charge-5-battery-draining-too-fast/m-p/5147332#M15061) I had to let it charge for 3-4 hours before the reset would work and I could see the Fitbit logo. I was getting the same slight vibration after every button push, and never saw the display / Fitbit logo.
After a long charge the reset finally performed as described.
However - and I certainly this is NOT the case in your situation - the resets were never a solution to my problems.
Best Answer05-20-2022 06:03
05-20-2022 06:03
I have the same problem with my charge 5. Five dots across the screen. I have tried all the suggested fixers and nothing works.
Best Answer05-20-2022 06:25
05-20-2022 06:25
I have just been through the whole process with Fit Bit Support and they couldn't fix the issue so am getting a replacement.
05-20-2022
06:43
13:12
05-20-2022
06:43
13:12
Hi, thank you for all your replies, and welcome to all the new users in the Community forums.
it's good to know that some if you were able to resolve with the suggested troubleshooting steps. However, if you continue to experience the same problem after the restart, I do recommend that you get in touch with the Customer Support team so they can provide you with the next steps. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Thanks again for all the feedback and comments that you've provided about this.
See you around.
01-16-2023 03:51
01-16-2023 03:51
This did not solve my problem....
02:53
10:14
DavideFitbit
01-20-2023
02:53
10:14
DavideFitbit
My Fitbit 5 totally died after less than a year of use....
Tried everything and more.....
This was my First and Last Fitbit.....
Don't need this crap in my life period
Moderator edit: format
10:13
13:12
02-01-2023
10:13
13:12
Welcome to the Fitbit Community forums, @AWHS @koos-strydom.
Thank you for sharing all these details about the inconvenience you've been having with your Charge 5 and for confirming that you already tried a few troubleshooting steps.
I've been informed that you already contacted the Customer Support team for further assistance with this. In this case, I recommend that you continue the communication with them and they will let you know how to proceed.
Have a good day.
Best Answer05-09-2023 04:29
05-09-2023 04:29
Last week my charge 5 choked...tried the three pusle restart procedure after recharging it...cannot get the screen respond to my taps...
I can initiate the pairing with my phone and it will ask me for the pairing code. Yet there is no way to get the screen turn on. During restarting the fitbit log will appear briefly.
Also the battery trains in no time.
Is there anything else I could try or should I contact support ?
Regards
08:14
13:12
05-12-2023
08:14
13:12
Hi, thanks for confirming that you're experiencing the same inconvenience with the Charge 5, @domidodo.
It seems that you were also able to get in touch with the Customer Support team. In this case, I do recommend that you continue the communication with them so they can let you know about the options available for you.
Best Answer05-12-2023 08:27
05-12-2023 08:27
Best Answer05-25-2023 00:02
05-25-2023 00:02
I bought it in AUgust 2022 with a 2 years warranty. So returned it and received a new one a week later 🙂
Best Answer06-13-2023 09:56
06-13-2023 09:56
@mochahantas Thank you for your reply.
I'm sorry to see that you've experienced this same problem with your Charge 5. It is particularly difficult when the device is no longer covered by the warranty, but even tough Support is eager to help with any problem you may experience with the product, they do need to adhere to the official warranty policy, this would start counting from the original date of purchase.
Thank you for taking the time to share your feedback regarding the quality; comments from users are always useful to continue improving the quality of products and services.
@domidodo Thanks for sharing your experience as well, it's good to know that you received a new device!
