02-28-2022 06:34
02-28-2022 06:34
Have rebooted several times via both Fitbit AND charger. BPM & Sleep Score still not showing. This is my second For it (no previous problems. Purchased Fitbit for three reasons: Steps, BPM & Sleep Score. VERY upset & now considering purchasing another option.
Best Answer03-02-2022 06:14
03-02-2022 06:14
Hi, welcome to the Fitbit Community forums, @TADN.
I appreciate all the feedback and details that you've shared about these inconveniences with your Charge 5.
Keep in mind that you must see sleep stages in order to see a sleep score. There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
If you see sleep stages but don’t see a sleep score, please note that it may take a few minutes for your sleep score to appear. In addition, for better results please try to let the device detect that you're awake or asleep by itself rather than doing it manually and make sure to keep the Fitbit app.
The Charge 5 may need some days to collect some information (particularly regarding to heart rate) and provide sleep score, sleep stages and other data. In case the problem is related to the Fitbit app and you not seeing BPm, please try the following as well:
Hope this helps, I'll be around.
