11-04-2021
17:04
11:32
DavideFitbit
11-04-2021
17:04
11:32
DavideFitbit
My Charge 5 doesn’t read my heart rate correctly when it goes above 165. It drops down to 100 all of a sudden when My heart is beating like crazy and the elliptical says 178. Anyway the heart rate tracker says I was in the cardio heat rate zone for 5 minutes but no zone minutes were recorded. It shows cardio heart rate even on the zone minutes graph but still doesn’t record it.
Moderator edit: format
Best Answer11-05-2021 11:31
11-05-2021 11:31
Hi, welcome to the Fitbit Community forums, @kitkat8675.
Thank you for sharing this information regarding the inconvenience that you've been experiencing with your Charge 5.
Keep in mind that you earn Active Zone minutes for time spent in the fat burn, cardio, or peak heart-rate zones. Heart-rate zones are personalized based on your fitness level and age. Before considering other options, heart-rate tracking can be affected by several factors including air temperature and device location on your arm; please make sure to follow the steps in this article to improve accuracy.
In the meantime, you can try restarting your device following these steps, and in case this problem is related to the app, you can follow the steps listed here below as well:
Hope this helps, I'll be around.
