02-04-2024
20:25
17:00
OpheFitbit
02-04-2024
20:25
17:00
OpheFitbit
My charge 5 has also died and will not reset or turn on - after reading so many others with same problem and Fitbits poor response- how can anyone trust Fitbit with any of it products or future support - I for one will never buy another Fitbit product
Hi there, @Wolgg @GiGiF74. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Fitbit Charge 5 devices are not responding to anything. I understand how you must be feeling. I will do my best to help you with this matter.
To better assist you, please confirm whether you tried restarting your Charge 5 as described here.
If the restart doesn't work and your Charge 5 doesn't vibrate during the restart process, please follow the steps below:
On a side note, please bear in mind that sometimes a Fitbit doesn’t seem to be charging when actually the issue is that it has become unresponsive (this can happen if the battery has been allowed to discharge completely). I'd recommend putting it on to charge on a charging wire and outlet known to be working. Leave it on the charger for a good two hours, even if it doesn’t seem to be charging.
Best AnswerI have tested the charge cable (with other user) cable working,
I have tried charging the device for long periods i.e two days - no effect
I have tried the reset numerous times - vibrates, then logo shows, then nothing
I have also tried removing app from phone and trying a factory reset - impossible with power / switching on
what would you suggest I do next ?
Best AnswerSame. My Fitbit stops charging last week and I didn't have a spare charger so I wore it until it completely went dead while I was waiting for my new charger to get delivered. Now I've had my Fitbit on the charger for hours and nothing. I've called customer service. They went through a few things, didn't work and then said we'll have to look into it and email you and that's it. So disappointed mine is less than a year and a half old
