Charge 5 piece that connects with band broke
Hey, I pulled the strap and the bit that connects the strap to the Fitbit broke off and disappeared. How do I fix this? Obviously can't just buy a new strap because I need the little connector bit. Thank you.
1 REPLY 1
Depending on the age of the unit, you may still be under warranty, eligible for a replacement. Otherwise, I think the only fix for that is either a new unit/ Fitbit or a slide-in band where the unit is encased, like this one. https://www.amazon.com/SUPCASE-Unicorn-Protective-Replacement-Wristband/dp/B09T3GGMHV/ref=sr_1_29?cr...
