10-29-2024 16:30
10-29-2024 16:30
Hi, I’ve had my charge 5 and Fitbit app on android phone just over a year.
A few months ago I noticed various reportings stopped showing on phone in app, after a while they would appear for a few days then disappear again.
notably it’s my “resting HR” my sleep score and most other “health metrics” eg breathing rate and heart rate variability etc.
ive switched mobile off, checked I’m synched ok, cleared cache, restarted charge 5 and probably a few other suggestions from here to no avail!
I’ve cleaned my charge 5 I’ve adjusted position to wrist, I’ve tightened and loosened band but I’m now right out of ideas.
please could someone advise on where or how, best I can progress my apparent technical issue?
many thanks. Sue
Best Answer10-30-2024 11:23
10-30-2024 11:23
Hello @Sewiknit2
I know there's been an issue that affects data syncing. However, the user reports I've read are in regard to completed workout data. This is the first time I'm seeing a report about missing/disappearing Health Metrics data.
Just to make sure I understand what you're experiencing, please confirm:
Best Answer10-31-2024 10:58
10-31-2024 10:58
Best Answer10-31-2024 11:41
10-31-2024 11:41
Hello @Sewiknit2
Thank you for the additional information.
By any chance, are you also having problems with heart rate tracking? Do you see a green light on the back of your Charge 5? You can check by placing your finger across the back of the device. You should see a green light when you lift your finger. The green light is the heart rate sensor and is needed for metrics like sleep stages, HRV, Resting Heart Rate,
If you don't see the green light, the first thing to check is that Heart rate is turned on in the Settings menu of your Charge 5:
If you have the green light, that's good news and your heart rate sensor isn't the problem. One thing you might try is wearing your Charge 5 on the inside of your wrist. Some users have reported that they're able to get their sleep data when they moved their Fitbit to the inside of their wrist.
Best Answer10-31-2024 12:47
10-31-2024 12:47
Best Answer11-02-2024 04:03
11-02-2024 04:03
Hi, sadly my problem continues- I did try moving position of charge 5 to underside of wrist a couple of nights but no difference.
im really not sure how to progress my problem really or with whom.
Sue
Best Answer11-04-2024 11:14
11-04-2024 11:14
Hello @Sewiknit2
Thank you for letting us know that your heart rate sensor is working, but you didn't get sleep data when you tried wearing your Charge 5 on the inside of your wrist.
The only other troubleshooting that I can think of is trying clearing the cache for the Fitbit app on your phone and restarting your Charge 5 after you clear the cache.
Best Answer11-04-2024 13:47
11-04-2024 13:47
Best Answer11-05-2024 10:41
11-05-2024 10:41
Hello @Sewiknit2
Thank you for letting us know that clearing the cache & restarting everything didn't work to restore your resting heart rate.
Trying your son's Charge 5 is a great idea. Charge your son's device to 100% first. Then, remove your Charge 5 from the app and replace it with your son's:
Please let us know how this works out for you.
