05-05-2022 07:02
05-05-2022 07:02
In every area on my Fitbit Charge 5 settings as well as on my app settings, I expect to get reminders to move on weekdays between 8 AM and 6 PM, and this used to work perfectly until the past couple of weeks. One day they stopped; I do not have sleep mode or quiet mode etc. engaged, and the app clearly shows the reminders are on. Poking around on fitbit.com in my device settings I found a section where reminders to move were labeled "Disabled" and there was an on/off toggle set to Off. I toggled the reminders back on and they worked for another day or two. But every couple of days I must get back on the website to change the toggle from Off back to On - and i have no idea why this is happening. Settings on the device and the app all agree these should be working. Help? TIA
02-18-2023 01:11
02-18-2023 01:11
Your solution not working. remind to move on my charge 5 has disabled
05-05-2022 12:01
05-05-2022 12:01
Hello @bepfarr
I would look to see if you have the latest update on your Fitbit App and update it if necessary. Sometimes logging out of the Fitbit App helps as well. Just log out of the Fitbit app, restart your phone then log back into the Fitbit App. If that doesn’t seem to solve the issue I would try restarting your Charge 5 ….you won’t lose any data doing so. Look here to see how it’s done: https://help.fitbit.com/articles/en_US/Help_article/1186.htm
Let me know how it goes and hopefully I’ve been able to provide you with a solution.
😃 Happy Stepping!
07-18-2022 12:22
07-18-2022 12:22
I just received a new Charge 5 and I have tried everything to get the reminders to move work and still nothing seems to work. I reset the reminders to move button on but it still won't work and when I go back it says disabled. I really like that reminder but really don't know what to do now!! Really is frustrating!!! Sorry you're having similar issues.
08-11-2022 13:16
08-11-2022 13:16
Mine doing exactly the same thing. I have now turned off the irregular heart rate thing above the reminder to move in the app. Only way I could get the reminder to switch back on.
08-16-2022 14:19
08-16-2022 14:19
Unfortunately it hasn’t worked.
09-21-2022 09:56
09-21-2022 09:56
Go into your charge 5 settings. (Sweep down from clock face). Go to Quiet Modes. Make sure your do not disturb AND sleep modes are turned OFF. Now mine works great. Worked originally and then stopped after update. My do not disturb had been switched to on!
02-07-2023 07:01
02-07-2023 07:01
I’m having the same issue
02-18-2023 01:11
02-18-2023 01:11
03-19-2023 04:10
03-19-2023 04:10
Only thing that worked so far, thanks for this!
05-03-2023 02:40
05-03-2023 02:40
DND wasn’t switched on. Where do you see “disabled”? Haven’t seen that but any changes I try to make on the reminder to move page vanish as soon as I leave the page. Worked fine when I got the Charge 5 2 weeks ago, stopped, I reset it, worked for 1 day and then no more. Grrrr!!!
06-21-2023 11:23
06-21-2023 11:23
I see Disabled in the app... tap on Charge 5 > Reminders to Move says Disabled (sometimes it says On or Off, but mostly Disabled) and I have done everything they've said to do (reset the app, reset the Charge, turned off/ on, synced, re-synced, DND and Sleep/ Quiet are all off... nothing works!)...
07-05-2023 01:26
07-05-2023 01:26
About half a year ago I bought an Inspire 3 which never reminded my to do my steps (even though I could see the info on the device itself), did not sync the hours, and also did not record my sleep. After much back and forth with customer service I returned it, and also the replacement they sent me which had the same behavior. I now have a Charge 5 and it was working perfectly until a week or two ago when it also stopped vibrating to let me know my steps were not complete. At least it is syncing properly. In my app everything is activated and is not being reset to disabled. My device and my app are on the latest version. I am going to try to contact customer service again, but I doubt they will be any help. You would think that they would have fixed this problem by now since your post is from over a year ago.
07-05-2023 01:29
07-05-2023 01:29
This is the best answer - I don't know why it isn't marked as best answer. I already wrote a comment before I saw this. My do not disturb had been turned on somehow (no idea how)! I just turned it off and hope that it will start reminding me...
