04-02-2023
13:44
08:17
DavideFitbit
04-02-2023
13:44
08:17
DavideFitbit
I just got a new Charge 5. Reminders to move do not work. After looking in settings in the app I can see that it says ‘disabled’ however if I click this the toggle is clearly on. When I return to the settings page it will say ‘on’ for a second, then return to ‘disabled’ while syncing. I’ve forgotten and reconnected multiple times, logged out and in again, double checked sleep mode and DND are off, app is updated… I can see an old question on the same problem is ‘answered’ however it was not actually answered! Anyone got any tips?
Moderator edit: format
08:16
08:51
04-03-2023
08:16
08:51
Hi, welcome to the Fitbit Community, @lou-tov.
I appreciate the information provided about this inconvenience with your Charge 5.
As you mentioned earlier, the option should be On when you go to your device's settings:
You can find more information in this article. If the issue you mentioned persists, you can also try setting up your Charge 5 as a new device in your account and then repeat the procedure to turn On the reminders.
Best Answer04-03-2023 08:49
04-03-2023 08:49
Hi thanks for your reply.
As I said, the setting is clearly already toggled to ‘on’, the problem is that when I return to the previous screen with the device settings, it says ‘disabled’ next to ‘reminders to move’
04-10-2023
07:34
08:42
04-10-2023
07:34
08:42
@lou-tov No problem, thank you for your response.
I've been informed that you already contacted the Customer Support team for further assistance with this and it seems that you already tried all the basic troubleshooting steps. In this case, I recommend that you continue the communication with them so they can let you know how to proceed.
Best Answer04-10-2023 14:54
04-10-2023 14:54
Mine says reminder to move is turned off yet I still get notifications of reminders
