10-04-2023 09:08
10-04-2023 09:08
Looking for Any replacement charging cord for Charge 5 that will fit on the back of the tracker
10-04-2023 16:28
10-04-2023 16:28
Hello @Herondoodle
I take it from your message that the charging cord that came with your device doesn't fit your Charge 5. If that is the case, you probably should contact Fitbit support for a replacement. You will need the official Fitbit charging cable for times when you need to reset your Charge 5.
10-04-2023 16:28
10-04-2023 16:28
Hello @Herondoodle
