12-23-2023
03:12
06:47
12-23-2023
03:12
06:47
When the battery is getting low of course I recharge it. But the fitbit symbol appears on the screen and my steps go back to zero
12-23-2023 06:58
12-23-2023 06:58
Hi there, @bullygrrrrl. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the inconvenience with your Charge 5. We'll be glad to help you with this.
In addition to what @gdio53 has asked you, would you mind confirming whether your Charge 5 is still paired to your Fitbit account and syncing properly? To do so, tap the Today tab, and then tap Devices.
If you find out that your Charge 5 is no longer paired, that would explain why your steps keep resetting and it goes to the Fitbit logo screen only.
If the above describes your issue, I'd recommend trying the following steps in the order listed:
12-23-2023 05:17
12-23-2023 05:17
Does it show zero steps on the tracker or in the app?
If it's on the tracker, it should get updated when you sync with your phone.
How low does the battery get?
Gary D.| Feeding Hills, MA MBG PE
Charge HR, Charge 2, Charge 3, Inspire 2, Charge 4, Charge 5, Pixel Watch 2, Pixel Watch 3
12-23-2023 06:58
12-23-2023 06:58
