10-11-2022
06:12
09:21
DavideFitbit
10-11-2022
06:12
09:21
DavideFitbit
I was wearing thr Fitbit, the screen flashed and now it won't come on again. I plugged it in to charge and pressed the little button 3 tomes as suggested. The Fitbit sign came onto the screen and then nothing happened, eventually the screen got an "x" in a circle.
09:21
09:54
10-12-2022
09:21
09:54
Hi, welcome to the Fitbit Community forums, @ErrorCharge5.
I appreciate the information provided about this inconvenience with your Charge 5.
This red circle you mentioned usually appears when a firmware update has not been completed or when there's a problem during the process. Make sure to follow the recommendations listed in this article if this is the case. If you already tried to complete the 3 pulse restart procedure and you continue to experience the same problem with the display, please try these additional steps that have been useful for other users:
Hope this helps, I'll be around.
Best Answer10-12-2022 13:37
10-12-2022 13:37
09:39
03:27
10-26-2022
09:39
03:27
@ErrorCharge5 Thank you for confirming that you already tried the steps suggested and that you continue to have the same inconvenience.
I've gone ahead and sent your information to the Customer Support team for further assistance, so you should be getting a reply soon. Please keep an eye on your inbox.
See you around in the Community.
