12-13-2024
07:35
09:05
12-13-2024
07:35
09:05
Hi
Can't conclusively work out how to contact Fitbit support or what to do here as device is faulty. Happened overnight. Any ideas what to do and how to contact?
12-13-2024 09:07
12-13-2024 09:07
Hi there, @Benharris19. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I understand your concern, I will do my best to help you!
If you haven't done so yet, please try the steps below:
If the above doesn't work, please restart your Fitbit device as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Regarding the battery short life, please follow the tips and recommendations provided here Can I extend my Fitbit device's battery life?
Best Answer12-13-2024 09:07
12-13-2024 09:07
Best Answer12-15-2024 03:05
12-15-2024 03:05
Hi,
The sync works. The battery has gone from 6 days to 9 hours in the matter of a day with no changes made to how I use it. I'm assuming a fault with battery since a sudden change. How do I contact re if warranty covers it?
Best Answer12-15-2024 13:32
12-15-2024 13:32
Hello @Benharris19
Please contact Support (<-- click link) regarding warranty coverage. Complete the prompts until you get the option to chat or call. It might be better if you call and speak with a support agent.
