01-23-2022 02:46
01-23-2022 02:46
It was working last week and all of a sudden it stopped working. It'll still turn on when I double tap
01-23-2022 02:50 - edited 01-23-2022 02:53
Hello @emilmil
Have you checked to see if it's still turned on? Sometimes after an update or something, settings can change. Is the big blue Screen Wake button you see when you scroll down from the Clock Face screen still set to Auto?
If it looks grey, please check to make sure that Sleep Mode is Off as that can stop the Auto Wake from working.
I hope that helps a bit.
09-21-2022 14:00
09-21-2022 14:00
Wibby,
Thx. Your suggestion was spot on for me.
Thank you.
