08-29-2024
08:26
10:44
ManuFitbit
08-29-2024
08:26
10:44
ManuFitbit
Holds a charge for less than 2 days. Stops working when battery at 60% charge. What’s up with that???
Moderator edit: clarified subject.
Best Answer08-29-2024 10:38
08-29-2024 10:38
Welcome to the forums @Walkernorthwest.
Thank you for providing the details regarding the difficulty that you are experiencing with Charge 5.
Please, make sure to follow the steps listed in this help article: Can I extend my Fitbit device's battery life?
Best Answer09-02-2024 08:25
09-02-2024 08:25
Greetings,
Within the past 3 days my fitbit's battery started draining really quickly. From a 100% charge it drops to nothing within a few hours. Before this, all the settings I was using were not a problem for the battery and a charge would last for days. Without me having done anything the battery now loses power really quickly.
So, is my fitbit's battery now nearing the end of its life? Or is this a firmware problem that fitibit still doesn't know how to solve? In the meantime, what should I do?
Thank you.
09-02-2024 10:36
09-02-2024 10:36
Hello @EricTheRed13 ,
When my Charge 5 started having rapid battery loss, I restarted and recharged my device multiple times over several days. As soon as I saw a rapid drop in battery, I restarted my Charge 5 and put it on the charger until it was back to 100%, often doing this multiple times in a day. Eventually, this process got my device "unstuck" and the battery went back to lasting 6-7 days. Although there's no guarantee that this will work for you, it might be worth a try.
Best Answer09-02-2024 11:02
09-02-2024 11:02
Hello Rieko,
Thank you very much for this tip. I will give it a try!
Kind regards,
Eric
Best Answer09-02-2024 13:50
09-02-2024 13:50
Ich habe das gleiche Problem seit gestern.
Best Answer09-02-2024 14:28
09-02-2024 14:28
Wenn ich fragen darf, wie alt ist Ihr Fitbit? Meine ist etwa 2,5 Jahre alt.
