10-11-2021 07:22
10-11-2021 07:22
When I start the swim activity it shows elapsed time for the duration of the exercise.
I want it show lengths of the pool (as it did on my old Versa).
Can I change the default display from elapsed time to completed lengths?
10-11-2021 07:41
10-27-2021 21:57
10-27-2021 21:57
This is the reason I bought a Fitbit. I made sure the charge 5 counted laps. I am dumbfounded that it doesn't show you how many laps you have done while in the middle of a workout. I thought this would an obvious feature. Considering returning the device unless an update will remedy this. Come on Fitbit, get it together.
10-28-2021 03:04
10-28-2021 03:04
@Aaronusername this feature has been removed from Versa 2 (it is supported on Versa) and since then it's always worth checking whether the watch can track laps on-screen during swimming. There's a theory (Fitbit has never confirmed it) the reason why some watches/trackers don't support real-time lap tracking is that those devices have no gyroscope. I wouldn't count the firmware update can change it.
Best Answer10-28-2021 04:01
10-28-2021 04:01
10-28-2021 04:49
10-28-2021 04:49
@Teucer true but it may be done on the server-side after analysis of the whole chunk of data recorded by the watch. I'm not really sure why Fitbit does it the way it does but it is what it is. I don't think it will change.
10-28-2021 05:12
10-28-2021 05:12
Best Answer10-28-2021 05:30
10-28-2021 05:30
@Teucer I don't know that, I own Sense and before Ionic which both shows real-time laps. If it's not server-side then still it may require full data in order to figure out the final lap count (some in-watch post-processing?). Only Fitbit knows that and believe me, Fitbit won't tell us.
Best Answer10-28-2021 10:46
10-28-2021 10:46
I'm pretty sure the charge 5 has an accelerometer. The screen turns on when I move my wrist. Sure would be nice if someone from @Fitbit could chime in here.
Best Answer10-28-2021 14:42
10-28-2021 14:42
@Aaronusername don't count that Fitbit will chime in 🙂 Readings coming from the accelerometer are usually very noisy and it requires applying a low-pass filter to remove unwanted high-frequency noise. It is required to do further signal processing, too. It is crucial to eliminate sensor noise. It may be that Fitbit devices are just not powerful enough to calculate and compute in real-time (Fitbit devices, in general, are rather on the lower end of hardware performance). Now, we know that devices with gyroscopes are able to count laps in real-time. Counting laps (and stroke recognition) may use data from as many useful sensors like magnetometers, barometers, etc. The more the better. It is possible to do it just with the accelerometer, though. The watch needs to detect turns and in general, it takes a bit of data to figure out that the swimmer turns. The turn may take 5-8 seconds (depends really on the swimmer, wall push-off takes some time). As much as it's possible to see the pattern in the acceleration, there is a lot of data to be analyzed and figure out what event has just happened. Now, with extra sensors like a gyroscope, it's possible to determine turn different way. It's because some events are easier to determine from one sensor while the other events are from another. Science says that the swimmer when turning reduces angular velocity and increases linear velocity. Since gyroscope data is less noisy (even without filtering) less computing power is needed. Also, it is easier to decide what stroke is used and what the lap count is using data from both sensors. Interestingly, even some swim strokes are easier to detect with the use of a gyroscope (breaststroke, front crawl, and butterfly - by observing a single axis of a gyroscope, it's actually a very regular pattern for each stroke). It is all possible just with the accelerometer but I think Fitbit tech isn't just performant enough to provide such data in real-time just using accelerometer. I see no other explanation (and Fitbit won't give any either) but all we can do here is just play a guessing game (well, backed with science) 😀.
Best Answer12-20-2021 19:59
12-20-2021 19:59
I agree! Seriously - I can see the length of time of my swim in minutes on the wall clock at the pool.
Anything other than that would be helpful.
Seriously disappointing considering other devices like Apple watches tell you what stroke you’re doing and everything! Mostly all I wanted was a lap count.
