10-13-2021 23:01 - last edited on 10-14-2021 09:18 by LiliyaFitbit
Hey there,
pretty happy in general with my Charge 5 but having big issues with a most basic feature: Alarms!
They randomly stop working for me, which also resulted coming late to an appointment. The only fix to that is deleting all alarms, restarting the device and adding them again. But I guess that should not be considered as a solution to the problem.
Obviously alarms are pretty important, especially for busy people. Any recommendations what to do? I completely lost trust in the feature. To make sure there won’t be a basic help center reply 😉:
* Yes I checked the vibration motors
* Yes I know they turn of automatically after a while, yet I pretty much wake up immediately by the alarm. Plus sometimes I was awake already but not moving at all and the alarm didn’t got off (well sometimes randomly it did even in that scenario)
* As described I restarted the device but the problem occurred again
Pretty frustrating tbh because the silent alarm per se is an awesome feature with the wife and a newborn in the same room.
10-14-2021 09:25
10-14-2021 09:25
Welcome to the Fitbit Community, @slngr.
Thanks for the details shared in your post and for already trying to resolve the issue. I understand how you are feeling and recommend reviewing our complete troubleshooting tips in this help article: Why didn't my Fitbit device alert me?
Hope this helps.
Best Answer10-14-2021 13:40
10-14-2021 13:40
That’s what I meant with „please no basic help center reply“…
I checked everything beforehand. For me it seems to be software related. I was also trapped in an endless snooze loop last week. If you use Google you see that this issue was also very common on Charge 3 & 4. So I am wondering if this was fixed in the past? For me it’s a bit weird that the Charge 5 e.g. is really accurate in automatic workout detection but fails at basics like the alarm.
Any other tipps apart from restart and stand help center stuff? Is there any way to send debug logs or anything from the device or the app?
10-14-2021 13:54
10-14-2021 13:54
Thank you for your reply, @slngr.
I appreciate your efforts and the additional details. I understand your concern and recommend getting in touch with our Support team so they can look deeper into the issue and help you with this matter. Click here to get connected with them via chat or phone.
See you around.
Best Answer03-29-2022 06:53
03-29-2022 06:53
Bonjour,
J'ai depuis ce matin exactement le même problème ! C'est extrêmement gênant quand on utilise les alarmes régulièrement pour plusieurs raisons.
Merci au SAV de revenir vers moi sans me proposer de relire la FAQ, ce que j'ai déjà fait.
Best Answer03-29-2022 07:18
03-29-2022 07:18
I had this this morning and have had a it few times where my back up alarm on my phone has woken me up. My fitbit still displays that the alarms are set to go off at 0500 and 0502 but they haven't. When the alarms do go off it always then shows the next set alarm. I have to restart the device to move the old alarms that didn't go off off the screen.
03-29-2022 07:38
03-29-2022 07:38
The same issue happened to me this morning for the first time. The vibrating alarm simply did not go off, and trying it later for other times did not work, either. In addition, my household has two different Charge 5 users and BOTH Charge 5 alarms did not function as of this morning. Was there a recent software update where Fitbit accidentally messed up the alarm functionality and now needs to go back and fix it?
03-29-2022 07:49
03-29-2022 07:49
It wouldn't surprise me as something broke the skin temperature reading so nothing showed in the app for 3 days and as of this morning the alarm didn't work and there is now no data in the spo2 area of Health Metrics.
04-12-2022 19:43
04-12-2022 19:43
Same thing here. I set the alarm over and over. It says alarm set, but when I look at it later it’s not set, and it never goes off. I’ve tried the restart, reset, all the usual stuff. It’s driving me crazy!! This is one of the main reasons I bought this thing when my Apple Watch died…to save some money and still have the silent alarm. But it’s useless.
Best Answer04-13-2022 04:01
04-13-2022 04:01
Thanks for bringing this up. I’ve had my charge 5 for only a few months and the alarms just randomly won’t work. The main reason switched from Apple Watch is so I can have long battery life and track sleep-which INCLUDES a functioning alarm! So frustrating that even when I reset it it just won’t work. And it’s completely random when it happens. I really hope I didn’t waste money switching to Fitbit.
Best Answer04-13-2022 06:16
04-13-2022 06:16
Idem mon fils a une ACE 3 et la première fois que mon alarme ne s'est pas déclenchée la sienne non plus heureusement je me suis quand même réveillée, mais pour son ACE3 c'est aussi un problème aléatoire, tout comme sur Charge 5 ! j'ai pensé du coup que ça venait de chez Fitbit et non de l'appareil seulement.
